Derrick M
Hello. Im having a issue here. Got hydramaster cds 4.8. it runs great, you can clean for hour straight until it cuts off or you turn the cds off. Then it just revs the engine up when you try and restart the cds. Its in a 2013 chevy express no engine problem no engine codes.
all lights on throttle box are solid
lube is up to date
all filters cleaned
checked all grounds
Salsa unit is functioning properly
no metal shavings around clutch
new belt and pulleys
traced all wires to make sure intact.
Is there anything im missing here? thanks
lube is up to date
all filters cleaned
checked all grounds
