Certified Pile Lifter Modification for Wet TM Extraction
B
B&BGaryC
Has anybody done this? Taken an old pile lifter, disabled the vacuum motor, pulled the bag out and hooked it up to the truckmount? This would not be a substitute for vacuuming, but would probably work wonders for the soil load. Unless you are Ron Werner you are still leaving crap in the carpet.
Gary;
It can be done, with the right parts.
You will need the Nylon brush, an adapter to hook up to the TM vac hose, and good seals on the object trap.
Larry
