Captain Morgan
Since the Hardware room is temporarily locked due to renovations, I thought I'd ask the question here.. About 6 weeks ago I had an issue with my Powermatic not keeping it's charge. I replaced the regulator on it and it seemed to run fine.
Had a cleaning job about 2 weeks ago and it shut down on me half way through. Tried to restart it but wouldn't catch so I let it sit while I paced outside behind the van... After about 10 minutes it restarted and ran fine the rest of the job. This Friday, cleaning some furniture.. finished the couch and same thing happened. Tried to restart and the battery sounded like it was getting drained. I let it rest for about 10 minutes, while I sat in the van to dry myself off a bit due to heavy rain. After about 15-20 minutes she started back up and I finished with no problems.
Saturday, cleaned 2 couches, loveseat, chair and livingroom carpet... not a problem. I was psyched thinking maybe it was just because it has sat quite a bit becaues business has been down? Today, I wanted to do a little maintenence and it wouldn't start. Grabbed the jumper cables, hooked up to the van battery.. started right up. Turned off the machine, unhooked the cables.. wouldn't start? Hooked it back up to the van battery and she started right up?
Has my regulator crapped out already or is it time to replace the stator?
