Doug Cox
- Joined
- Dec 17, 2006
- Messages
- 4,925
- Name
- Doug Cox
So I'm from Wisconsin which can be lethal in the winter. I have a job on the 9th floor (top floor) of a highrise condo building this morning. By the time I finish running the hose and dropping the water line down, going down to hook it up and get going, the freaking water line is froze at the couplers (200 Ft.). I drop the hose back down, thaw the hose, run super hot water through the lines, drop the hose again, start cleaning and fought the vac hose clogging with ice for the next 3 hrs. before finishing. Had to de-clog the hose numerous times throughout the job and probably was up and down in the building ten times. By the time I was done all the vac hose was frozen, 1 vac hose broke. I generally will make an attempt at a job if questionable, but the temp was at 24 degrees at the start which wasn't bad, but it dropped into the teens by the end, but the wind chill is what I think did me in. Haven't had a frozen hose in twenty years. Oh, and by the way, it was on a lake, which makes it that much worse. My whole head was red from the cold. What a ride.
