Cimex problem - Only rotates 1 direction
Jesse
I picked up a used R76 that will only rotate 1 direction. It just makes a hum when you turn it on for right rotation. I've lifted it off the ground and it wont move at all. The other direction is strong. I was able to run it with a 40lb weight.
What's wrong?
Am I hurting the motor running it like this?
Jesse
Using it on carpet. Today it's hall racing 2 19's in a huge old folks home.
It rotates easily in both directions by hand. It won't rotate counter clockwise even off the ground. Just a hum.
Arizona
the humming noise should indicate it is getting power to the motor....off the top of my head I would check the start compactor....more then likely it is a reversible type.....
Latest Auctions
