citrus-solv question
E
easy1dave
I use citrus-solv a lot.It has allways had a orange tint to it.I got a gallion the other day and it was clear an did not have much of a smell.Has any bode else ever got citra-solv that was clear?Thanks David
Dave;
If it is primarily d-Limonene citrus solvent, then there are several items that come into play.
Some products have changed the concentration of d-Limonene in the formulation.
Being a natural product, the growing conditions will have an effect on the color.
The color starts out clear and yellows slightly when exposed to air.
It will also affect the fragrance, but not to the same degree.
I would check it for solvent power first,
and then fragrance.
Larry
Get with John Olson and get some Ultra Citra Boost .some of the best citric out there....VERY concentrated..
normally 1/2 to 1 oz is all you need....It goes a long way....
It mixes great... and is consistent threw out the entire mix....
C
Curtis Pennington
Which brand you using?
