Dan
So this evening I was bored and decided to do a test based on a video I watched the other night. Something I knew but didn't ever test with whats currently in my truck. What you are seeing is a double shot glass filled mostly with filtered water from my refrigerator and then a tablespoon of the citrus you see behind it. I shook them both and set them down and watched. I then added 1 more tablespoon to the one on the left only to better show the results and repeated the process and took the picture 30 seconds after setting them down.
guess I know which one will be going in the hydroforce and it stayed mixed. The other will be used as a spotter.
What do you use for hydroforce or spotter?
