Cleanco Admiral Pump replacement
PCCN
I have an older Cleanco PTO (1998) and need to replace the original Admiral pump that came on it. It is starting to pulse a bit. Problem is Admiral is no longer in business. I would like to replace the pump with as near as I already have to make it easy and fast. Any suggestions? Admiral model XLS-2543, 1750 RPM/4.3 GPM/2500 PSI 1450 RPM/3.5 GPM/2500 PSI
