WE HAVE THE RIGHT MODEL FOR YOU!
STANDARD COMPACT TRUCKMOUNT EQUIPMENT
Precision Balanced PTO Shaft
100 Gallon Waste Tank
Twin SS Blower Filters & Lint Basket
5CP Plunger Cat Pump - Clutch Activated
Roots Whispair DSL Vacuum Blower
Dual Coolant Heat Exchanger System
Quick Release Instrument Control Panel
Dual Solution Connections
Dual 2" Vacuum Hose Ports (45 & 47 models)
Dual 2.5" Vacuum Hose Ports (56 models)
Carpet & Upholstery Speed Settings
Blower & Pump Oil Site View Lines
Easy Access Blower Lube Port
SS Carpet Wand
150 ft 2" Vacuum Hose (45 & 47 models)
100 ft 2.5" Vacuum Hose (56 model)
50 ft 2" Vacuum Hose (56 model)
10 ft 1.5" Lead Vacuum Hose (45 & 47 models)
150 ft High Temp Solution Hose
Chemical Jug
Whisper Pac System
High Temp Shut Down
Park Break Sensor
Anti-Theft Module
5 Year Extend-A-Care Warranty
SS Carpet Wand
Chemical Jug
Whisper Pac System
High Temp Shut Down
Park Break Sensor
Anti-Theft Module
