AshleyMckendree
So a month and a half ago I decide to buy a 20lb co2 tank + regulator so I can fill my pepsi sprayers on the fly without getting 3 or 4 ready at the shop before leaving ( why I stopped using them), and also I can mix the chems as strong as the job called for.
So Ive realized on some of the GREASY spoons I clean, when I spray down carbonated grease eraser it bubbles up the nasty grease almost INSTANTLY, and Im not having to get out my 175... not only that, Im mixing the GE weak, 3 (3oz) scoops to 3.5 gallons.
1 pepsi sprayer with 3.5 gallons and 90psi lasts 3 good size restaurants, spraying generously... Before I was using half a hydroforce at 1:8 ratio,
Cleaned 4 trashed empties (900sqft apts) with one sprayer full, and had enough left over to wash my wand & hoses off after we finished.
Also, I have charged up my pepsi sprayer at least 50 times, at 90psi and my co2 gauge is only showing that its gone down 1/4 its charge... although I dont know if the gauge works properly.
Anyone else have a positive experience similar to mine using Co2?
AND it only costs 25 bucks to re-fill a 20lb, a smaller 10lb is like 12 bucks and would be a little more convenient.
