Cobbs Powemax as a rinse
alazo1
San Jose, Ca.
Albert Lazo
Just got a pail yesterday. It has dilution ratios to use as a rinse.
Anyone use it for a rinse?
Albert
Jeremy
Indiana
Jeremy
Albert
:shock:
I wouldn't... It doesn't rinse that well with water let alone in the rinse water... Use it for prespray on the nasties (& use a rinse agent). The stuff cuts grease like a champ but... Unless it has been reformulated it I'd say its a bad idea to use it as a rinse. Just my opinion.
floorguy
Utah
Doug
never used as a rinse...why would you need to, works great as a prespray.....75% of your jobs, mix it at 2 oz per gallon...orrrrr 20 oz in a hydroforce
Hawaii
Too bad the label doesn't say other wise. Ivebeensold
Last I remember it was 8oz per gallon.
tman7
Tacoma, WA
Tony Gillihan
That might be Cobbs recommended dilution ratio. I have used it 2oz per gal for light soil and 4oz for heavy, works well. I have also noticed chem makers tend to recommend more than is really needed.
alazo1
San Jose, Ca.
Albert Lazo
I thought it was odd too about the dilutions for rinse, I think 3 cups in the 5 gallon tank, meter at 2-4. Seems like it would leave a residue.
hopefully Larry will chime in.
Just dusted off my hydroforce which I haven't used in months. Will try it in a restaurant tonight.
Albert
Dallas, Texas USA
Albert
Hi Albert;
It is used primarily as a prespray product.
It can be used in the extraction rinse, if time to clean is the main driving factor.
Dilution ratios are difficult to determine;
one customer may have a 100 PSI portable with cold water,
versus a 38 HP, #5 blower with 240° of heat.
Amounts of prespray will also vary from cleaner to cleaner.
For rinsing I would only use about 1 oz. per gallon of cleaning solution.
Thanks for the question.
Larry
