Coffee On Berber.....
rwcarpet
Youngstown, Ohio
Robert Hodge
What would you advise a custy for a coffee spill on a light berber carpet. It's a little out of my service area......Riverside, Cali.
encapman
St Petersburg, FL
Rick Gelinas
Hydrogen peroxide: Blot the carpet with standard supermarket grade hydrogen peroxide using quality paper towels (i.e. Bounty), or with a cotton towel.
Reactions: Mark Saiger
For large spills use a wet/dry vacuum (or Shop-Vac) to extract the bulk of the spill. If just a small amount was spilled, blot with a white towel to remove as much of the stain as possible, then neutralize with a solution of 1/3 cup of white vinegar, 2/3 cup of water. Saturate spot, using a spray bottle and blot to remove excess moisture. After neutralizing, go to step 3 of general procedure. If any discoloration persists after area is dry, try misting with undiluted 3% Hydrogen Peroxide ( $1.99 brown bottle from the drug store) once a day for a few days to see if the stain lightens.
Depends if it has sugar in it or creamer. Creamer will get sour if you don't remove it. I would charge them extra and have a client and cheerleader for life. Flood extraction and a water claw and bring a air mover to force dry..
Heart of Dixie
Someone spilled COFFEE? The heathen! After slurping it back up, I'd go get some kerosene and level the whole joint befor the Almighty got really pissed.
