Step 1) Clean and prep area - make sure no waxes / sealers / topical coatings on floor
Step 2) Apply product
Step 3) Lightly mist with water
Step 4) Spread all over tile and grout with white buff pad - working into grout
Step 5) Wipe ColorSeal off tile with damp chamois
Step 6) Final - clean wipe with very clean and damp chamois
What kind of prep work goes into showers with mildew?
Do you need to put any products on to remove any bacteria or can you just clean with a scrub brush and color seal after?
What about the use of bleach? Can you seal after using bleach to clean?
You can use any product that works to prep. The main thing is to make sure that the ColorSeal is being applied to raw grout to insure a good bond. Showers are tricky do to the moisture and every shower floor will be different - depending on how well the pan is working.
I've never seen it applied like that. We squirt the color like you did, but then we squeegy into the grout lines, towel & buff. I'll have to try your way next time. Thanks, good video.
Hey Nino, yea, i figured that was you in the video. Did Steve get confused on how to post again.....I say you take his computer away and give him back his crayons....
