Does anybody combine cleaning methods and if so which ones and how--we got HWE--Encap--the OP thing--and using the crb machines with that dry compound stuff--I currently have a Mytee M5--Mytee hot turbo heater--Rotovac 360i with standard head that came with it and also the carpet brush head and i also have a 175 with carpet brush and a mounted 4gal solution tank--I was thinking--pre vac ( always of course) then crb machine with dry compound stuff--then another vac--then HWE with good rinse solution only to finish up, would not leave carpets to wet and would dry quickly and would be able to extract everything out including any left over dry compound stuff that may have gotten left behind what are you r thoughts about this method or maybe some other combination
