There is absolutely no rush. Thanks for getting back.
Thanks for taking the time to talk with me this afternoon Jim! I will post about pre-sprays first and then work my way down the recommendations people have suggested and add any feedback and maybe include some products I did not see on the list.
First, If you have never tried
Ultrapac®, I would highly recommend it be one of the options you chose…especially for use in residential cleaning situations. It is by far our best-selling liquid pre-spray.
Ultrapac breaks down oily soils and creates maximum soil suspension, while leaving minimal residues…. Also, one gallon can make up to 33 gallons of diluted pre-spray.
There are three options you can chose from:
Ultrapac® (fresh
light mint scent)
Ultrapac Mint the same product with an enhanced mint scent, or
Ultrapac LVC (Low volatile
compound), which is the same as well but with no scent**
when mixing and applying the product you will have a chemical odor, but it should dissipate in a few minutes. Nothing in the cleaning industry comes without asterisks.
Other Pre-Sprays that are popular sellers:
Power Burst - Uses enzyme technology and highly recommended for use in heavily soiled restaurants as it works wonders on meat fats, veggie oils, grease, and protein based soils. Powdered product which a lot of cleaners like/prefer! One 6.5lb container makes up to 34 gallons of RTU pre-spray
Power Strike: Another powdered product…recommend for use on rental homes, apartments, dorms, offices… Fast “striking” surfactants (you see what I did there?
) means a shorter dwell time but still provides effective soil suspension. Works best on carbonaceous soils. So, red dirt, sand, dust, clay… One container makes up to 34 gallons of RTU pre-spray
Axiom Clean – Our “green” cleaning line... It is bio-degradable, phosphate-free, VOC complaint product that meets or exceeds all major green programs guidelines. It is versatile and the strong solvents cut through oils and grease and are safe enough for residential 5th generation carpets, wool area rugs, and natural upholstery. This is a liquid product which, I believe you have a preference for powdered?
We have additional pre-sprays for specialty cleaning scenarios, Fine-Fabric (which will be included in another post), Upholstery pre-spray, Olefin Pre-Clean. If you are interested in more information on those let me know.
