Hello and thanks to all who respond and help me--I am not new to carpet cleaning using the HWE method--i currently own a Mytee M5 portable--Mytee hot turbo external heater--Rotovac 360i with standard head that came with it and also the carpet brush head and i also have a 175 rotary with carpet brush and a mounted 4gal solution tank--my current method is pre vac--apply pre spray using 175 with carpet brush with pre spray solution in tank on the 175--followed by rinse and extract with portable extractor--i've been chomping at the bit to get into "dry cleaning /very low moisture cleaning for both residential and commercial but mostly for commercial as i want to do mostly commercial in the future--i checked out one of those CRB machines at a local supplier who gave me a demo and let me use the machine there in the store--he did demo using both the encap solution and the dry compound stuff-- i was suprised at how easy it was to use the machine and manuver it around also the machine was pretty quiet as well, i was also impressed at using the dry compound stuff
So my question i guess is who uses this machine and method, how do you like it overall, what type of results do you get in the real world out there with it or is the machine really not worth the investment as they are not cheap--can i use my 175 with carpet brush instead then just use a vacuum to vacuum up the dry compound stuff with just as good results? The 175 is like 90 pounds and the crb machine is only like 50 pounds so i see that as an advantage and a back saver as well--also think the crb machine would be great to use as a pre spray agitator for pre spray when doing HWE as well instead of that heavy 175
