Mikey P said:
Got a closer look at the
Sapphire Porty..
Sent from my DROID2 using Tapatalk
The Willy review
1- Heater
How many watts on that? 1000? You get a good heat at 3200 and that can be lacking if the tap water isn't piping .I use a bucket heater if it's luke warm or daisy chain a second 3200 if there's enough juice.
2- Pumptech POS pump. Slip a pair of 1103's on that and you might get 175 - to 200 keyed. And it's suggested not to run it past 350 psi.It's the same POS in the Ninja
Warrior - I have one and it/'s garbage. Both Hypro and General make pumps that both work and last, but the manufacturers still push the pumptech trash.(Although John L is building something with a General- kudos for q-tip usage)
3- 2 WHOLE freakin' 2 stage vacs. That'll suck dust off the moon. Not. I retooled the Recoil once with 3 three stage vac, but it was too hot and drew too many amps, but it sucked seriously. I went to 3 hp 2 stage, 2 in series a parallel for boost - Great vac, but not as good as my quad vac set up.
Just the same old, same old bullshit. Somebody needs to step up to the plate and build a real machine with quality components. It's just the same cheap ass stuff in another package. :roll: :roll: :roll:
NEXT!
