S
Scott Rogers
The commercial job I am currently doing had a extreme amount of soap in the carpet. layers of soap. The Janitorial staff pad clean the halls and conference rooms about every night with grease Lightning and Betco dry foam. I could not find a measuring cup in the janitorial closet, so I imagine they use the glug glug method.
The loss of vacuum is instant. areas they haven't been maintaining (the offices) have no issues.
I have tried crystal defoamer, it helps but I still have a significant vac loss do to the foam.
What will are the possible issues of putting liquid haven't in the rinse tank so I have a steady supply of antifoam? What would be a good dilluton to a 5 gallon stock tank.
I can rinse with a acid too or just run the defoamer. i have used acids before here and doesn't seem to strip much out.
