Nate The Great
Ok, someone asked in The Hardware room the difference between the old rotovac 360 and the new one. I took video on it but I keep getting a error message. I took some pics in the mean time.
The older one has a 1.5" port, with the twist knob on the right to adjust the handle, shorter base with the whole base being the vacuum chamber, smaller wheels.
The newer one has a 2" port, push button handle adjustment, longer base, larger wheels, better vacuum chamber, L shaped vacuum shoes. If you look closely in the pic, the 360i has a spacer on the shaft of the head (not that head Brian R, you perv). The head on my new 360i has the 3 white knobs that are no longer put on the new models. The L shaped vacuum shoes I guess solved the problem or something..... *shoulder shrugs*
Notice the adjustment knob on the right. The teeth have been wearing down adjusting it.
This is the new rv360i base.
