Direct mailers??
R
Rescue
When you all were back in your early years starting out with only a small customer base. What company did you like for direct mail. Has anyone ever used it, if so what are your thoughts. And what companies have you used. I have heard of RSVP, Postcardmania, info-usa; there are many.
Joe
A
alazo1
RSVP is a val pak type of advertising whereas info-usa is where you buy a mailing list. Totally different.
I've read a lot have had good luck with rsvp. If you have a postcard in mind and want to send out individually then info-usa for the list and a printing house such as www.gotprint.com for the printing and mailing.
Albert
J Scott W
Jeffrey Scott Warrington
BridgepointDirect.com can handle all the direct mail services you need. Provide mailing list with whatever filter you ant, design a piece, do the printing, mailing, etc.
Get a code from your local Interlink Supply distributor or send me an email with your address for a code. After you log on, they will contact you for a guided tour of the web site and explain all their services.
Scott Warrington
Blue Monarch
Dirk Wingrove
I went to the site Scott, but was a bit turned off by the tour process. I feel that the site tour should be available without someone having to call me and explain the process.
If I've got questions after seeing the site, I'll call. I avoided going any further with the site because I felt like I'd be spending my time keeping a salesman at bay if I continued.
My guess is the site is a good one with many benefits. I just want access to more info without hoops.
Latest Auctions
