when you run a rinse do you find yourself running an acid or alkaline rinse more often and why.
I have heard dry slurry is good....
Acid left somewhat of a softer hand, yet as far as resoiling I could not see any difference. Supposedly alkaline will re-soil faster. Didn't happen, And with the alkaline rinse, definitely less re-appearing stains.
For those that are using an alkaline rinse with an alkaline PresprAy, any resoiling concerns?
Never and we live in small town usa where there are limited numbers. You're only as good as your last job.For those that are using an alkaline rinse with an alkaline PresprAy, any resoiling concerns?
I used to run RO water, but after doing some side by side comparisons on two carperts I clean regularly, the rinse worked better than the RO water.
Trashed Green. No resoiling. Mix it 10 oz. per 5 Gal.
Mike, test at your home, if you have carpet.I run prochem all fiber rinse. (acid) I'm pretty new to the rinse thing though. Only been using it for about 12months. I used to run RO water, but after doing some side by side comparisons on two carperts I clean regularly, the rinse worked better than the RO water. Left the carpet softer, less wickbacks, actually, no wickbacks at all. One of the carpets I cleaned had at least a dozen or more juice and soda and milk spills so it was definately a good demo. Before I would see some wickbacks around 3-4 days later on this clients carpet with RO water (my neighbor) The results didnt lie. No more RO water. However I am open to trying other rinses.
Which is cheaper to run?
Thats a bold statement Mike.
and would piss off a lot of the pure water fags.
I am going to quote these words, because they do contain the truth as this is the same for me.I used to think folks were making up their supposed problems with wicking to make a case for whatever chemical or procedure they were advocating, as I've never had a problem with it. Slowly, over the years, I've come to understand that I was just lucky that I was simply a better cleaner than those folks. Thank God that I am not like them.
