This was my second day dual wanding all day.
It holds 220-230 on two ti wands, with .12 flow each - solid. It never dropped below 220 from what I can tell. No fooling around. That's running at 2600 rpm - it goes to 3k rpm. It would probably go hotter if you ran it higher.
I imagine it might go higher soon, because the water box is dumping into the waste tank at 95 degrees instead of 180. There is a faulty safety valve. Because of that we have been going through 250-350 gallons on a regular job. So, it's bypassing very quickly. I expect to get 230 when it's fixed. PowerClean FED-X'd the part but it's not here yet.
Fuel- It's hard to say, but I did an eight hour day of cleaning on the machine and drove - 80 - 90 miles and it used 14 gallons of diesel. Ran the air conditioning and drove fast.
Noise - the DXT in my machine is quiet, partly because the engine it is quieter than a gas engine (I don't get that). And because of the install that PowerClean did. Lot's of sound deadening and carpet. They also have really good silencers.
So far, I am very pleased.
