I don't recommend it...But it can be done...!
If you have the larger blower 5.8..."Which is only a 4007"..
The 1st. thing you have to do is remove the vac hose from the live reel...
Your vac lines...have to run "directly from the top of the waste tank....
One of the ports is 2.5 inches..the other is 2 inch....
Run 50 ft. of 2.5 in hose off the 2.5 in port...then your 2 inch hose.....
"Use this hose for you longest run" max 200ft total..."dueling"
Then attach a Maximum of 150.ft of 2 in. hose to the other 2 in. port...
THESE ARE MAXIMUN RUNS..to dual wand with..!!!!
Also MAXIMUM flow of "SIX".."If you are using 4 jet wands"
If your 1st. run needs to be 300.ft...
Then "single wand"..with the 2.5 hose until you get to the 200ft.mark..
"This will help Balance the vac"...Run the unit on "Mach II....
Now for the solution lines....
Turn off your valve to your Fresh Water Tank....
You "MUST" hook up direct to the front of your machine..."SUPPLY HOSE" to water source.
Run 50 ft. of 3/8 solution line ...then insert a 1/4 TEE VALVE....as a "Splitter"...
Adjust your CAT pump to at least 800 psi...This will help equalize the pressure ...
Make SURE the UNIT is running in the RED.."RPMS"...can be adjusted under the hood
by adjusting the actuators..." If your
Butler is not a NEWER one "...????
The "
Butler's"are NOT the best units to Dual Wand with...But it can be done... :roll:
MOST of the time it is easier to move the VAN....or....drop hose from a window.. :idea:
