GeneMiller
I've have a lot crack over the years. I just figured it's the cost of doing business. I read the manual this time just for geers and the max water temp is 100. I always fill the solution bucket with 200 plus water. Then run the prime. Probably causing my own problem. They always crack at the bottom. Just using cold water now. Time will tell.
Gene
Gene
