I was told you could not put a slide in on an E150 due to load. Looking to put an SS Rage into 2003 E150 is this a no-no due to load or some other reason??? Any input at all?
how much does the Rage weigh?
isn't that their bitty unit?
if so, and contingent on how much other gear you carry, a half ton can work .
That van should be right around 7200 GVW if I'm not mistaken
If heavy duty, might even be 7700
Look at the sticker on driver side door post
You're good for 1200-1500 pound everyday payload
be sure to use the best tires you buy, fill to max PSI and rotate them religiously
wouldn't some helper springs take care of that?
It's not so much the suspension, Charley
Nor the frame, drive train and brakes.... as Ford builds the most robust 1/2 trucks on the market .
hell their brakes on their 150 are as heavy or heavier than a 3/4 ton rAm dUdge truck
(to dUdge's credit, they did upgrade their brakes from the tin-willy JOKE of a system they started out with)
but rather, It's the 15"
tires that are that are the weak link .
a 15" tire can only haul so much weight.
It's actually the tires that are the limiting factor on most trucks
example, a one ton single axle truck has a GVW of 9400 give or take
That same truck w/dual axle jacks it to 11,000+
