ELECTRIC SPRAYER BARGAIN
Willy P
Willy P
I always put down prespray with:
# 2800 PSI (193 bar) piston pump
# Pressure control 1000 to 2800 PSI
I suppose you could switch out the pump?
But its still the basic set up as the other carpet cleaning sprayers out there for sale.
Jimmy;
More limitations:
Flow rate: 0.22 gpm (0.841 lpm)
Also, these paint pumps are required to be cleaned out after every usage with a cleaner.
I doubt any real professional painters use this rig.
Larry
Jameszz, I didn't see a price on that POS.
BTW, are you thinking for pre-spray or painting??
buy a "real" paint sprayer if you need one.
(they start at about $399 and go up from there)
Or buy a cheap Harbor Freight Wagner hand held knock off.
(they go on sale for under $40)
That way when the POS Wagner (or the knock off) quit working right, you won't feel so bad about pitching it in the TRASH
I was looking for the gpm, cause that 1/2hp motor ain't making anywhere near 1000 psi, let alone 2800!
