electric sprayer
need advise on buying a electric sprayer ive heard about all kinds here, hudson,rocket sprayer,bug sprayer,omni, what is the preferred choice that most guys have that are not piles of junk .not to many problems. thanks scott
The first and most important question to you is: What capacity do you need it to have?
packfancjh
Chris Hagen
Are you going to suggest Mytee's sprayer Mike? Cause that would be a surprise.
Brian R
Brian Robison
I'm thinking of changing from my Hydroforce to an electric sprayer just for proper mix. Sometimes it seems the HF doesn't mix evenly.
Not to mention, prespraying while the TM waits patiently to be turned on...sounds like my girlfriend. :wink:
I need something that sprays hard and fast.
Anyone?
Certainly not the one I have but maybe the new version that I'll be testing soon.
Along with what Mike asked,
I'll ask, what's your budget allow?
If two gal of pre-spray gets you through most jobs, the Multi-Sprayer is hard to beat for size, reliabilty and versitility.
We used one for years and years.
We still use one (battery model) for deos, protectants or when there's no power.
They're not cheap though.
for the last 4 years, the Hydroforce 3 gal 110vt electric sprayer is what we use 90% of the time
http://www.rotovaccorp.com/sprayers-hydroforce.html
reliable, EASY to mix powders in, and 3 gal capacity, as well as the ability to drop in gal jugs
you won't go wrong with either the Multi or the HF electric
Brian, if you want to put spray down in a hurry, you'll need to change the jetting in the wand on the sprayers I mentioned.
Change the jet to 06 or 08 flow.
You'll get real close to 1 gpm
(which isn't far behind those unreliable in-line sprayers)
Johnny
Johnny
I like the battery Multi-Sprayer because you can mix as many two-gallon jugs as you need for the job and switch them out as you go. Also don't have a fixed reservoir to clean out between different chems.
