Encap Equipment
jmo
Tucson, Az
Jeremy
If you were going to get some new equipment for encap what would you get and why?
I'm thinking of getting a brush pro and a cimex. Or would I be better off getting 2 brush pros?
Shane Deubell
One of each, the cimex is great for wide open areas.
Never used a crb for encap but it looks like it would be better for cubicles and tight areas in general.
Reactions: jmo
Derek
NY
Derek
for CGD? the Trio is the only CRB i'd consider or recommend in that field.
I see no mention of using a 175/300 rpm buffer so I'll add that for max sq ft cleaning.
Or is encrap really cleaning or is it smearing in the dirt?
Noble Carpet Cleaners
Dribble, foam, scrub/smear, blend. Oh, then run. I personally like Scrub-n-Run.
I can put some serious damage on comm. glue down with my 175. It's slow, maybe 900 sq. per hour sometimes 1000. Cimex would be nice but even nicer would be a serious wide area vacuum cleaner. Our choices in wide vacs has shrunk in recent years. On most commercial that doesn't get vacuumed I'd say powerful/fast vacuum cleaner first, then 175 then Cimex then accounts then Chimps.
tmdry
DC
Bill Martins
No need to buy new...buy used, it works the same.
