Engine RPM
tman7
Tacoma, WA
Tony Gillihan
Can anyone tell me how to adjust the engine RPMS's on a Boxxer 421? I haven't checked yet to see what Im currently running at but my temps are down and just want to readjust if it turns out I am not running at the standard 3000 rpms when I get a hold of a tachometer.
Thanks
Fort Worth , Texas
I am pretty sure you can tune and adjust idle rpm not sure you can raise top end rpm in any way other than making sure it is running correctly.
Maybe someone more familiar with small engines can tell us how if it is possible.
Able 1
Wi
Keith
On my TM (Peak) 25 horse, all you have to do is back out the screw on the carb.. Just look at the carb when you pull out the throttle to see which screw it hits..
