Epoxy Floor Cleaning & Maintenance
SMRBAP
Anthony
Anyone have any rec's for cleaning & maintaining an industrial grade roll on epoxy floor? Just the epoxy, was not cleared.
I have a tenant 5680 with the nylon brushes, it's not doing so well. Cleaning dirt we track in from the vans and roll around with the lifts and pallet jacks. I was thinking maybe trying pad drivers and a non-aggressive pad?
Any advice on what pads or brushes and chem's (and dilution) to use appreciated!
175 w/red or brown pad.
Portable or TM and a Hard Surface wand rinse @ 400 psi.
If a neutral pH cleaner doesnt cut it, try UltraPak Extreme
Reactions: Condog and SMRBAP
Try blue or green pads on your 5680. You might have to do a 175 scrub first with neutral cleaner
or degreaser also to get it where you want. Then maintain with auto scrubber. They’re pretty much bulletproof though.
Condog
Tony
Can you use the 5680 vacuum only, instead of wand & TM (porty)?
Latest Auctions
