Brian and Rex are correct, there is a limit of speed and power transfer to work from.
That said, even 2 blowers running at 70% provide a lot of suck when ran in true parallel configuration, lets say you are getting 225 cfm from each blower at 15"hg, 450 cfm is pretty impressive, it would take a 47 or a T-408 to be screaming to make the same cfm at that lift.
So I'm gonna say, get at least a well plumbed and properly driven T-408 or 47 if you don't want to give up any vacuum.
Now....that said, if you aren't running 2.5" hose, or 4 to the door, than half of what i just said is moot, you may feel the vacuum is impressive and indeed it may be, but a single 2" hose for 150' is only gonna yield so much suck regardless of two blowers or a single larger blower.
