So lets hear it guys, lets talk about the pros and cons of each unit. Why did you go with what you did? If you had it to do over again what would you change? What kind of vehicle do you have it installed in?
Me personally? My elbow is a little rusty from lack of upholstery cleaning.Do you mind a little rust?
I know it didn't come off the Prochem machine... Yea, it's going to kill me when I finally start back up...for a little while.My elbow is a little rusty from lack of upholstery cleaning.
Getting both Zippers and a good wand with glides for sure...and an RE. Butler says it takes 6 to 8 weeks to build my Van and I will be in the Gym everyday. Should be fine... I also have a Son and other big guy family help in place when we finally get moved to Texas.Use an RE or Zipper and you'll be fine. If you must sling a wand get one with a glide...maybe two glides.
1000 psi is perfectably acceptable for tile and grout cleaning. If you're going to pressure wash, get a pressure washer.I like both from what ive seen but have owned neither. The Sapphire supposedly had some rust issues and is definitely a big unit. They told me it wont fit in a transit. I do like the high pressure capability. The Everest caught my eye in Nashville. I think I would like the E-idle as well as the fact that it has a slightly smaller footprint and will fit in a transit. I dont like that the water is only heated to 1000 psi. after that you bipass the heat exchanger. Not really exceptable in a machine at that price point.
I agree but what about grimy garage floors. Theres lots of instances where I see myself wanting 1500 psi of hot water. Thats my holdup with the everest. Its the most expensive slide in but will only heat water to 1000 psi.1000 psi is perfectably acceptable for tile and grout cleaning. If you're going to pressure wash, get a pressure washer.
They aren't heated.So get a pressure washer.
http://www.landa.com/ViewCategories.aspx?Pid=1018 Many are.They aren't heated.
Both good, but I have had good luck with the 650, I did the timing belt at4K and was in great shape.. 5600 hours and very impressed still. Gobbs of power with 2.5 plumbed to the lint trap
Have you owned both?Both good, but I have had good luck with the 650, I did the timing belt at4K and was in great shape.. 5600 hours and very impressed still. Gobbs of power with 2.5 plumbed to the lint trap
