Albert, just some food for thought, but you may want to hit the mold with a little microbran space spray plus to actuelly kill the mold roots first, then follow up with a good bleaching agent to clean the mold. Otherwise bleaching usually only removes the surfaces spores and not always the roots, allowing it to return quickly.
Another possible option if you find that bleach/pressure isnt' removing it all the way.. you could always try a media blasting equipment.
On a not of the original question regarding adding bleach (sodium hypochlorite) to Powermax... why not use the bleach first, let dwell, rinse and then follow with powermax.. just a thought. household bleach is not a product that should be readily mixed with anything. And while I don't think there would be a reaction, its better to play it safe rather than chance the creation of the chlorine gas.
