Firestorm VS Flex Powder
Scott S.
Scott
So i've been testing firestorm out on jobs i usually use flex on, and im getting ok results, but the flex does better.
I'm also getting foam with the firestorm, but not with the flex.
anyone else getting these same results.
firestorm smells nice, citrus all the time gets old.
Reactions: J Scott W
mirf
David Mirfin
We like the firestorm better in theaters that serve food.
Scott S.
Scott
i clean a number of restaurants monthly and im not getting as good a results with the firestorm.
Is it a liquid? Seems like liquids with a solvent content always foam up more.
Todd
I can't tell the difference between most of them. They all work good IMO
I don't clean restaurants (hate the hours) but I do plenty of trashed rentals.
Now I am doing FWR and can't tell much difference between the rinses either.
Able 1
Keith
I really didn't care for firestorm.. I'm using Flex now and I like it.. Still like Powerburst, those two are close..
For the Flex I mix it like I do my powerburst 6 scoops to 2.5 gallon jug,and spray 4 to 1 in my hydroforce.. I think Powerburst is a little stronger at this mixture.
Todd
You are using about 1 ounce per gallon at that ratio, nice
So what Liquid Presprays work best ? I am tired of dealing with powders. They have my chem feed all clogged up too. I know what my favorite ones are just wondering what other guys are using
Mike Draper
I love to run ultra pac though my cimex on nasty commerical jobs. Keeps the P.H under 9.5 and easy to rinse and neutralize.
I just wish they would make powerburst that had a decent scent instead of that chemical smell.
Reactions: Able 1
Scott S.
Scott
so did a side by side with flex powder and fire storm tonight, they both take the grease off the carpet, but the flex powder really excels at getting the ground in food to loosen from the carpet. where the firestorm doesn't so much.
I can say this though, I'm going to use up every ounce of the sample I have, it works well, and is very close to the flex, but I feel its just shy of the goal.
