realclean
Has anyone ever had a set lock together so hard that you could not get them apart?
Will they swivel at ALL, if not it sounds like it has somehow got full of silt/grim. If this is the case I would remove them off the the hose and flush with hot water and some WD 40 and try to work them back in forth till you can flush the gunk out.Tconway,
I have a pair locked together that the button will not push at all. So how do I get them apart? I cannot see inside until I get them apart right?
I could see this happening if it was on a set that was not taken apart very often, the design is subject to silt getting in and filling the groove up once that happens no way they are coming apart.
