Take the time and tilt you cab and check all of them.........
With the way that the UD vibrates at a idle or when driving if they are laying on each other and not secured the right way they will rub a hole in each other
I blew a gas line as I backed into the drive way tonight (best place to do it I guess) ......In this case the factory gas line was a little to short and had a bend in the rubber at the clamp and it finally just gave way........all is good now I ran down to the parts place and picked up a rubber gas line and replaced it.but I noticed that I has some hoses and lines rubbing each other and putting wear spots in them...........
so first chance I get I will separate and secure all of them..........
Just a heads up.....
