Go to urine treatment?
Mr Brightside
Jay Wags
Describe your process for urine odor I have been having some issues lately with getting the odor out typically I pre treat heavily with an osr and then let sit for 10-30 min
Then clean as normal by pretreating with enzyme like bio break and extracting
I like to do just a heavy acid rinse to start. And go from there
If a heavy stain remains, treat it with the 40vol or something like stain magic Harvard
If an odor remains, treat with a liquid enzyme, then spray with normal juice in the HF and HWE with the heavy acid rinse again.
Leave behind the 40vol treatment if any stains are there after. I’m too lazy to do the fancy oxidizer/uv light method. It takes too much time
Kenny’s just upset that you asked what I have. He doesn’t like Soap Daddy’s products. You see, the owner of Soap Daddy is black and not socially acceptable in Kenny’s world.
However, his products are outstanding. What Kenny doesn’t realize though, or he might not have rolled his eyes, is that I haven’t actually had any experience using Soap Daddy’s products on cat urine. I just don’t encounter cat urine hardly at all. So, his prejudices didn’t need to be called upon. I do have Cat Attack, which is apparently board approved here, but haven’t had to use it.
Donwand
Brian
7% acetic acid works every-time for me. It takes some time to work a minimum of 2 hours. Pour it on the area and after a couple hrs flush with water and extract with a water claw.
Lord, you wrote all that and still got it wrong. That ranked right up there with Matt’s rant!
Surely if he wasn’t new here he wouldn’t have asked your product of choice for pee😏
I have used your product of choice and found
it works.
Do you have to ask for a race card or is one included when you order P-sor? Is it valid anywhere or just when Soapdaddy is mentioned?
I must have missed the post where Kenny expressed his racial issues with a soap product.
I have a really hard time believing that ever happened.
That the only racial issues involved with that product whatsoever is when the founder chose to knock off Ultrapak and spelled it exactly the same and make a carbon copy of the chemical, and when legend brands sent him a cease and desist his response was something to the effect of the white man trying to bring the black man down...
  • Wow
Fyi, I’ve used it because you swear by it and it’s done the trick the few times I’ve used it, jackass. Since I don’t have much use for dog or cat piss products I don’t have to make that comparison. You made a lot of assumptions, which makes an ass out of you, but not me.
Soap Daddy products work
Cool Cuffs are the best
Cuffs are another forum waste of money that was pushed on these sites. Get a machine with decent suction, use the plain Jane grey cuffs and go make some money.
If they're not making you any more money, don't waste your $$$ or time installing them.
Meter Maid
The Undetective
Chris
I don’t get it. The plain cuffs narrow the space between hose and obviously cut airflow. The outer cuffs allow full airflow.
I saw one of my competitors a few years ago running 2.5” hose to the door and I know he uses the plain cuffs. Seems counter-productive.
The reason I use locking cuffs is because vinyl cuffs are hard to separate when new and come apart too easily when aged. When I started using electric reels, I got tired of being slapped in the face or nuts by a flying hose end.
There's not enough difference in suction to matter. I've used both types.
Flash cuffs give you better airflow.
Swani
They're a huge time saver when it is cold as f. out. Trying to connect vinyl cuffs when it's freezing cold, is more frustrating then watching a Roger Lloyd video.
