You might want to look into Loctite HVAC Blue Pipe Joint Compound. My guess would be $700.00. Do I win anything? lol
I have the same chemical feed pump on my Vortex. Did your truck not come with one? I have a blue spring on my pressure relief valve. It's rated at 3,000 psi, but I wouldn't turn it up any higher than 1,500 psi.
I clean tile at 1000-1200. I do use higher pressers to wash the trucks. Anything over 2000 psi. is asking for a line to blow, or valve to go bad.
So what happens if I want to run 2000+? Does it stop out at 1500? Guess I need to research how they work.
Sent from my DROID RAZR HD using Tapatalk
A video would be nice.
