Here are some pictures of before and after of installing Green glides 2.5 inch elbow adapter on my Cobb unit.
I had to cut off the original 2" aluminum fitting and grind off any excess flush with the tank. Then I had to cut 1/2" off the back side off the new adapter, drill two new rear mounting holes, and then trim the gasket and punch new holes in it. I made a template of the mounting plate out of card board to mark the 2.5" vacuum hole and then used a roto zip to cut it out of the tank larger than the original hole. Drilled the mounting holes using a #7 drill bit and then tapped them with a 1/4" - 20 tap. I had to do this so I could thread the stainless 1/4" bolts and washers from the inside going out so they would stick up like studs because I would not have access to tighten the nuts once the adapter was on. Then put some rtv silicone between the tank and gasket (tank was not perfectly flat there), and bolted the assembly down. I took the second picture before I cleaned up the excess rtv silicone because it stopped raining for a minute and I could get my camera back out but it looks much better than the finished picture.
