Ryan said:
How big of a deal is it if I've been using the carpet protector on upholstery? :shock:
If you and the customer are happy, then all is fine. It certainly is not doing any damage.
The upholstery protector does have a few special features that you don't get with carpet protector.
1) The upholstery protector contains Dye-Loc. This stabilizes due and prevent issues with bleeding and to some exten issues of browning. One of the reasons some folks choose to use a solvent on upholstery is to prevent bleeding or browning.
2) The polymers in the upholstery / fabric protector are much more flexible. Protector wears off carpet mostly due to abrasion from foot traffic. But protector comes off upholstery mostly becuase the fibers bend and move when someone sits down, shifts their weight around, gets up and so forth. Eventually the polymers crack and break off from the fabric.
You won't have this issue with Maxim Advanced Upholstery Fabric Protector with Dye-Loc. The flexible polymers keep it in place much longer than competitive products and longer than the less flexible carpet protector polymers.
3) Surfactants in carpet protectors are intended to make the protector penetrtae down into the pile of the carpet. Upholstery fabric is so thin it does not need this ability. Rather it should spread out and level out well. If it penetrated it, the protector would only be wetting the stuffing or filling material. It would also take longer to dry than if the protector stayed on the thin layer of fabric.
Longer drying could make wicking and other issues more likely.
A point I have made more than once before, there is a lot more involved in the formulation of cleaning products than the average cleaner realizes.
