As the title says, I've been thinking a bit lately as to which is better? High heat or high flow? Some of you guys are lucky enough to be able to have both but that's not really my case. I am running a white magic pro 1900. For those of you that don't know this machine it it has a 5.9 blower turned by a 52 horse ford engine. I'm running 2.5 inch hose except for the last 40-50 ft or so where I cut back to 2 inch. This machine has a pre heater which pulls heat from the cooling system as well as an exhaust heat exchanger, but no blower exchanger. I use high production tools, or should I say high flow tools right now but my heat definitely suffers because of it. My wand is a quad jet ti running 03s, I have a 360i with the 4 jet head but I'm not sure what size jets r in there, and my Hoss is set up like Jim Martins with the long spray bars and a needle control valve. My next purchase is likely to be a Zipper which again is high flow. So my question is this, is high flow worth the heat loss or am I better off choking things down and maintaining higher heat? Secondly do any of you have any ideas on how to get more heat out of my machine? Thanks all in advance.
