everything on the machine is a closed loop system....when you start vaporizing your chemicals.........that's outside your machine....your only running a rinse and most the time it is not ran threw the entire system...
I have worked on closed loop system boilers that get hotter then any of our machines...and the only thing that has any effect on them is the water...softener is the best place to start.............
