Lol @ Zee
tmdry said:
Brian, can't find your cart sprayer thread. Which hose do you have on your sprayer and what is the length on it. I have a Fimco 8 gallon sprayer, it's built so cheaply the handle broke off, I can still use it, it works fine just no handle to carry around. Need to either spend $80 bucks on Mytee's big boss handle or possibly go with someone similar like your cart. Would the mounting plate u made upfront be able to hook up a larger oval shape/flat bottom tank?
Just a 1/4 inch (I think) 150 psi hose from the home depot 65 feet...plumbing dept. Same thing we use with Chem -Dry years ago.
I'm getting ready to do a 5 gallon tank or bigger on that cart...the 2 gallons are a pain because I will use that upstairs in no time....and I really don't like the holder.
I will take that off and just have the new tank sitting on the bottom plate...it's just a $40.00 "Harper" cart from Lowes or The Home Depot.
I need to buy a pump that turns on and shuts off as I spray. The one I have is continuous....it's made to be placed on the orbot and finger triggered.
I have to unplug it to turn it off...G.H.E.T.T.O.
I rigged it up...and I'm not really happy with it. I was going to go with a pepsi sprayer but they have their issues as well.
I Will put the pump at the top of the cart instead of the bottom too. Won't get wet AND the plug is right there.
I may do it today...I'll post pics.
I would probably also go with closer to 75 feet of hose...the big houses I've been doing lately require me to bring it into the house. Pain.
I just run the extension cord down stars after vacuuming so when I'm finished spraying upstairs I can unplug it from up there to turn it off....did I mention "Ghetto"? lol
