rwcarpet
If one wanted to install a newer TM that requires a fuel return (fuel injected), and the current tap only has one line, can you drop the return line into the fuel neck without causing any problems, such as a static charge? Or would the return need to be all the way into the tank like the draw line is??
I have a TM I want to buy, like next week, and pull the Genny out, install the new TM, which requires a return fuel line, without installing a brand new tap. My current van has a single fuel line tap. This new TM will eventually go into a box van, which I haven't got yet. That will have the proper tap on it when new TM is installed. I just would like to get this new TM up and running ASAP, until I can find a proper box van for it.
I just don't want to create a fire (or explosion) hazzard with the fuel return line.
