I'm more confident then ever that I'm gonna whoop yo' ass!
meAt said:no side show tricks like you running it over on my side to show dIrtY wAteR being pulled thru yjr clear vac tube
Mike Draper said:We need some rat nasty carpet for this comp..
WTF is a rocket surgery
Mikey P said:Same mount, same hoses and same chems will be used.
Larry, I'll take a unmarked pos 1911 instead of the $500.
Mikey P said:yeah, we agreed on $500
you told me you were so sure, you'd give me 100 to 1 odds
my $5 bucks to your $500
Ron Werner said:if all you guys are going for is appearance, may as well throw in a OP machine and a Greenhorn with a stiff grooming brush.
Or is the point to see how fast to get it "acceptable" appearance?
kolfer1 said:Ron Werner said:if all you guys are going for is appearance, may as well throw in a OP machine and a Greenhorn with a stiff grooming brush.
Please God........
Don't get Ron started...........
I'll give up Twinkies.
Lee Stockwell said:First time I've ever seen Capitoni back pedaling?...just a bit
Mikey P said:Is the backing sound on the peice Larry?
meAt said:Mikey P said:Is the backing sound on the peice Larry?
why??
will it be to MY advantage if it's not??
if so, I'll keep looking
yea it should be OK , Cody cut it, so i haven't seen the backing yet, but wasn't noticeably delaminated that I cold tell
It's not that old, maybe 5-7 years
I'll try and find another piece between now and then too so we'll have a couple salvage rags to play with.
But I'm not going hog wild, cause I don't feel like hauling a couple hundred sf of garbage for ten hours to Nashville....
ya...but bring the carpet too............I don't feel like hauling a couple hundred sf of garbage for ten hours to Nashville....
