Jul 15, 2014 #1 Johnny Supportive Member Joined Oct 22, 2006 Messages 2,375 Location La-Z-Boy Name Johnny Got a HOSS yesterday. Which, if any, flow restrictors do you use and at what PSI do you run? (I have a 47 blower and 2.5" hose.) Much obliged.
Jul 15, 2014 #2 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin start with the small one and see how it does....then try the next size up...you will be able to tell which one will work best for you.... Or.......you could not use them at all and get a high flow kit with a needle valve and control it how ever you want...when you want...... Reactions: Johnny
Jul 15, 2014 #3 hogjowl Idiot™ Joined Oct 7, 2006 Messages 48,477 Location Prattville, Alabama Well then WHY don't they just put one of those at the FACTORY? You're all up their butt ... Won't they listen to you?
Jul 15, 2014 #4 Scott S. Supportive Member Joined Feb 3, 2008 Messages 3,234 Location PA Name Scott I run without disk, but didn't upgrade to bigger spray bars, but I usually use my rotary drimaster when I need limited water. Reactions: Johnny
