Hot Van / Chemicals
realclean
Bossier City, LA
Jesse Lowe
This time of the year do you keep some of all your chemicals on your van?
Is there any chemicals you remove due to the heat this time of year?
I am just wondering as I try to not keep some items like solvents, peroxides.
icleancarpetz
Rafael Samson
Buy chems that are not effected by heat or cold nor lose potency after you mix them RTU and storing those same RTU jugs.
Those factors alone is what you should shop for in a detergent.
Ask those questions of your suppliers before you buy.
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
I carried a little cooler for my liquid oxidizers, reducers and solvent spotters. Those were the main products affected by heat. You can toss a blue ice pack in with it.
Spurlington
On The Board
Spurlino
Somebody should invent a Styro Shelf to keep chems cool or warm depending on the time of year
Maybe even a small tube going into the closed shelf to feed heat or air depending on time of year
