ThaBeast
I made templates from thin blue foam and had these panels water jetted fron 3/16 steel. These are bolted to the door using stainless bolts. The insides of the doors were rattle can under coated and filled with scrap blue foam from lining the van.
We welded a piece of 3"x3" L steel to the panel, slotted the factory plastic panel
Mounted crappy Rokans to the steel L
The doors are now very solid sounding. Passenger door holds live water supply feed and drivers door holds apo hose
