two with the Ti wand in most cases, a few more in transition areas and hundreds with the I
FCC said:wet passes do you do? How many dry?
Jamesh921 said:one dry pass for every wet pass.
I'm one of those cleaners who hold the trigger and go all the way across the room with a wet pass. Then, go back over the same area with a dry pass, making sure to vac the "puddled" area at the back of the wet pass.
The more soiled the area, the slower I go. If it's really trashed I break out the 175.
