It really varies from engine to engine, pretty widley. That's why it is important to consult the owners manual.
Older, simpler engines take a drastic toll that newer, more sophisticated ignition systems don't. As such, as a rule, but not always, a 4 cylinder engine, that sees duty in more expensive application often have much higher service intervals for the plugs.
Some small two cylinder engines use a relatively harsh spark that often may fire once per revolution (by design), instead of just on the top of the compression stroke. These will degrade the plug tip much more quickly. Engine RPM and load also takes a toll. A two cylinder running at 2500 RPM, versus a 4 cylinder far below 2000, and less load will erode a plug faster, even without the wasted spark.
Small engines also may not have an iridium tipped plug available, that extends life.
